Page 20 of 25 FirstFirst ... 101819202122 ... LastLast
Results 191 to 200 of 242
Thread: Saturday at home, installing an inverter
  1. #191
    May 2015
    East London
    Is there a way of calculating approximate back up time when battery banks are connected in parallel? (Total of eight 6volt batteries 240Ah)
  2. #192
    May 2015
    East London
    Quote Originally Posted by blackknight72 View Post
    That is at 2000 Watt consumption. I would also like to know if it is okay to add a second bank at a later stage. Will it damage the first group of batteries?
  3. #193
    Mar 2012
    Account_Deleted
    Nice simple calculator
    blackknight72 (08-Jul-15)
  5. #194
    May 2015
    East London
    That is
  6. #195
    May 2015
    East London
    My inverter installation is almost complete. However when I switch the kettle on with the mains on , the inverter beaps with a message indicating overload. Why does this happen when the mains are supplying. I connected the kettle on another plug point still with mains on and there was no problem at all. Any clue what could lead to this?
  7. #196
    Diamond Member tec0's Avatar
    Jun 2009
    I know in older homes if you turn something on like a kettle the lights would "dim" for a second and go normal again. Could it be that turning on the kettle creates a dip in the power flow for a second that causes the beep?
  8. #197
    You may have a UPS inverter, in other words the load is always supplied by the inverter, and the battery is always on charge/stand by, so effectively the load can then not exceed the UPS rating at any time.
  9. #198
    May 2015
    East London
    It is an Axpert 3KW MKS plus.
    Interesting enough the Inverter doesn't bleep when i use the same kettle in other power points.
  10. #199
    May 2015
    East London
  11. #200
    I'm not sure why that would be.
    Did you sort out the problem with the inverter error code indicating overvoltage on the batteries? What was the cause out of interest?
  1. [Question] Installing new electrical outlets in my home
  2. Was Saturday 11th's Important Announcement a bad PR exercise?
    By gac in forum South African Politics Forum
    Last Post: 13-Feb-12, 01:37 PM
  3. Installing Pastel express V.11 on Laptop.
    Last Post: 07-Dec-11, 02:52 PM
  4. Installing Windows XP on VB
    By Faan in forum Technology Forum
    Last Post: 17-Jun-11, 07:18 PM
