Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Geyser Problems
    Jun 2014
    Midrand
    Geyser Problems
    Hi i have a problem with my geyser, i replaced the element and the thermostate but the water is very very low, i tried to increase the level on the thermostate but still nothing. my geyser is not leaking, the water only went low so i changed everything i could but still nothing please give me advice on what ells i can check
    Bronze Member msmoorad's Avatar
    Jan 2009
    durban, SA
    Quote Originally Posted by Roland26 View Post
    what do u mean "low"?
    low temperature or low quantity of water in geyser?
    Geyser Problems
    Hi Roland and welcome to the forum.
    I've taken your post you made in someone elses intro thread and made it into a new thread of its own for you.
    Jun 2014
    Midrand
    hi do you have a suggestion for me regarding my geyser????
    Jun 2014
    Midrand
    yesterday i changed my circuit breaker but the geyser still dont want to get warm, what ells can i do
    Mar 2014
    I take it there is electricity at the geyser terminals?
    Houses4Rent
    083-3115551
    You need test equipment to go any further. A geyser is a very simple device, first you need to test the supply at the geyser itself. If you have 230v L-N and 230v L-E and 0v N-E then you need to test the voltage across the element terminals. If there's 230v across the element and it's not heating then it'sa faulty element. If there's no voltage across the element then the switch contact in the thermostat isn't closed so the thermostat is either incorrectly set or it's faulty.
    If you're not competent to carry out electrical tests or if you don't own a tester or if you're not sure how to prove the if supply is present or if it's isolated then rather call an electrician.
    Jan 2009
    durban, SA
    What could be the problem is the enery/power saving cutoff that many here in Durban have installed on their DB. Its set to switch off the geyser at a certain time. In winter, this causes the water in the geyser to get cold, though in summer, u find the waters still hot whenever u need it. Our ones are small white boxes made by Ellies.
    AndyD (03-Jul-14)
  10. #9
    Very good point, I assume thisdevice is a ripple relay or is it a programmable timer. Either way these types of devices maen the geysre could be automatically switched on or off at any time which means safe isolation is more important than ever if you're working on one.
  11. #10
    Diamond Member wynn's Avatar
    Oct 2006
    east london
    Also your new thermostat probably needs to be zeroed, quite often they stick when new or temperature is changed, simply turn the little heat gauge indicator all the way to max (You should hear or feel it click) then turn it all the way back to zero (you should hear or feel it click again) before turning it to the desired temperature setting (do this last setting in a single movement because if you stop halfway that may result in the temperature being set at the pause position).
  1. geyser timer???or not
    Last Post: 15-Sep-16, 09:35 PM
  2. Geyser 200kpa
    By Mike-too in forum General Chat Forum
    Last Post: 14-Apr-13, 09:29 PM
  3. Problems with a Franke Geyser
    By Martin6876 in forum General Chat Forum
    Last Post: 04-May-12, 03:24 PM
  4. Geyser serial No:
    By TECHNICIAN 810 in forum Electrical Contracting Industry Forum
    Last Post: 21-Jun-11, 03:42 PM
  5. geyser problems - some advice needed please
    By SilverNodashi in forum General Chat Forum
    Last Post: 21-Apr-11, 09:25 AM
