Results 1 to 7 of 7
Thread: Sole Prop naming issues
    UGU
    With the new companies act now well and truly running, what is the legal status of a sole prop.
    For Example, someone registered a company with name xyz. now a sole prop that opened his business a year before with the same name wants to challenge this business owner.
    What are the legal points on this?
    Kind regards,
    Marius du Plessis
    Jun 2010
    My guess of an answer is:
    (a) Don't think the new companies act changes this in any way from before especially as the sole prop is not a company. Its actually the Consumer Protection Act that covers trading names.
    (b) It becomes a "trademark" issue and depends on when the sole prop started using the trading name - before or after the new CPA. If its recent then there appears to be very little protection for a trading name unless it is registered with CIPC - in fact I don't even think you can use them anymore. If however, the sole prop had the trading name for at least a year before the CPA came into effect, then he may have a stronger claim to the name.
    I suggest you take a closer look at the CPA for more guidance.
    Mar 2012
    Vanderbijlpark
    I recently registered a defensive name for a client, that was vaguely similar to a US based global company. Within weeks I received objection papers from a SA based law firm and eventually I had to sign an undertaking that I would not use nor renew the name.
    The CIPC are only able to compare names to registered names, defensively registered or otherwise. Use of a trading name that is the same or similar to a registered name is not under their control, but is a copyright issue and usually boils down to "birth right".
    The CPA attempted to control trading names by insisting that they be registered with CIPC, unless they were in use for at 12 months prior to the implementation of the Act. However it seems there were implementation issues and it is actually not in effect. See this pdf issued by Astrid Ludin on 5/6/2012. To my knowledge nothing has changed.
    2012_06_05_Registration_trading_names.pdf
    BusFact (23-May-14)
  5. #4
    UGU
    What protection does a sole proprietor have if the sole proprietor only opened his bank account last year?
    Can he claim the name as his own?
  6. #5
    Quote Originally Posted by Taxempt View Post
    There's certainly no IP protection in that on its own.
    All other things being equal, my understanding is it really is a case of who started trading under the name first.
  7. #6
    Platinum Member sterne.law@gmail.com's Avatar
    Oct 2009
    Durban
    You can register a trademark at anytime.
    If you register a name, that someone else is using, then that person my challenge the registration.
    Trademarks are protected in terms of legislation or the common law.
    The common law is the passing off and / or unfair competition.
    The issue is, can a customer be confused/deceived.
    Anthony Sterne
    www.acumenholdings.co.za
  8. #7
    Bronze Member Beancounter's Avatar
    Oct 2011
    Pretoria
    If you can prove that you've been using the name for an extensive period of time, you should have no problem registering a defensive name with the CIPC.
    Proof would constitute invoices made out to your business, advertising in the name of your business and listings on pages that you can retrieve that go back a while.
    See the CIPC website to lodge a complaint against the new company using your name.
    Remember to renew your defensive name after 2 years.
  1. Changing a Sole Prop to a (Pty) Ltd
    By Incentive in forum General Business Forum
    Last Post: 21-Mar-14, 07:04 PM
  2. [Question] Sole prop tax issues
    By Kris in forum Tax Forum
    Last Post: 16-Aug-12, 01:33 PM
  3. [Question] Sole prop expenses
    By Nico Erasmus in forum Tax Forum
    Last Post: 10-Aug-12, 06:40 AM
  4. cc/sole prop
    By murdock in forum Business Finance Forum
    Last Post: 11-Nov-09, 08:18 PM
  5. A few questions about CC VS Sole prop
    By Pap_sak in forum General Business Forum
    Last Post: 20-Sep-08, 01:00 PM
