Results 1 to 5 of 5
Thread: Problems with logo in Xpess09
    Apr 2014
    Hi all,
    Wondering if anyone here can possibly help me? I have read threads and done what I could to create an invoice in the Forms designer. I have come unstuck with the logo itself, and have the following questions:
    What size must the logo be to ensure it is visible? I have tried different sizes, to no avail
    Where, or in which folder should I save the .enz file and also the .BMP image?
    Is there any further steps required to get my invoices to email or print with the revised format?
    Thanks in advance for any help you may be able to provide.
    Platinum Member Mike C's Avatar
    Apr 2012
    Durban
    Hi HiPix - our logo is 1.29x0.76 cm (150x90) and is kept in the "Custom/Forms folder" and is in jpeg format (300x300 dpi)
    Our enz files are saved in the folder which is created when you create a company (usually company name which is limited to 8 characters)
    I have the following enz files: csdocpdfsp.enz; csmthpdfsp.enz ; csdocsp.enz ; and csmthsp.enz
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you do know and what you don't. - Anatole France
    Apr 2014
    Hi Mike, thanks very much for that, it worked! Last question....how do I get pastel to now use that invoice?
    Aug 2009
    Durban
    Quote Originally Posted by HiPix View Post
    It depends on what you have called your customised document. for instance if you formatted csdocsp.enz, then in the file - printer fonts - invoice - paper style you need to choose single sheet plain paper. csdocSP.enz
    SR means single sheet preprinted
    SH means single header-preprinted
    Hope that helps
    Maureen
    Apr 2012
    Durban
    Pastel apparently "looks" first for any relevant .enz file in the company folder and uses that before it uses the default file. So if your enz file is in the correct folder, then Pastel should start using it automatically.
  1. Logo on Pastel
    By Hermanb in forum Accounting Forum
    Last Post: 18-Jan-12, 07:39 PM
  2. Trade mark/Logo
    By Martinco in forum General Business Forum
    Last Post: 23-Jul-11, 09:01 AM
  3. Survey - Which logo?
    By I Robot in forum Administrative issues
    Last Post: 28-Sep-06, 04:15 PM
