Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: IT14 and Accumulated Losses - no provision in return to record it
    May 2013
    Durban
    What a silly thing for SARS to omit in the 2012 IT14 via e-filing.
    I read on SAIT that they are aware, recommend that we do not file, and that it should be corrected by May 13.... well, so much for that!
    I still havent filed, and contacting SARS themselves is spectacularly unhelpful.
    The only option is to record an accumulated loss as an "Other Asset" in the balance sheet... am so wary of doing this, as fear one day in the future it will have disappeared in terms of tax treatment consideration by SARS.
    Curious how others have chosen to handle this particular problem.
    Thanks - AMB
    Mar 2012
    Vanderbijlpark
    I presume you are referring to the new layout that came into effect on 4 May? Because prior to that it was fine.
    If source code 4604 has been omitted, have they omitted 4642 also (Other debit capital and reserves)?
    I too would be uncomfortable with Other Asset. If you do use that, I would suggest you "request a correction" once they have fixed it
    May 2013
    Durban
    See attached screenshot
    "Once they have fixed it"Click image for larger version.
Name:	IT14 - no accrued loss.jpg
ID:	3585.... is a real pipe dream, it seems.
    I called the SARS hotline, waited the obligatory 20min in the queue, got a "what?" from the call centre person who then disconnected me :-)
    Sent SARS an email a week ago, and not holding my breath for an answer
    <sigh> sars
    Platinum Member Mike C's Avatar
    Apr 2012
    Durban
    In my experience their email responses appear to be "copied and pasted" and usually don't answer the actual question at all.
    Keep us posted if / when you get a response. It will be interesting to hear.
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you do know and what you don't. - Anatole France
    Mar 2012
    Vanderbijlpark
    It is available now
  6. Thank given for this post:
    AMB57 (31-May-13), Dave A (30-May-13)
  7. #6
    May 2013
    Durban
    Clive - are you sure? When I open up the IT14 its exactly as per the screenshot, ie nothing changed at all. This is a 2012 IT14, just to be clear. Am I doing something wrong - maybe there's a way to refresh it? Wouldn't want to have to start again unless no other choice. But just want to make sure before doing anything drastic - any ideas? Thanks, AMB
  8. #7
    Mar 2012
    Vanderbijlpark
    Yip
    It's on page 5.
    If you created the return before it was fixed, I suggest you mark it as "manually submitted" and request again
    AMB57 (01-Jun-13)
  10. #8
    May 2013
    Durban
    Clive I will do so - thank you, u r da man
  11. #9
    May 2013
    Durban
    Clive (or anyone) - please help. I tried your 'manually submitted' suggestion, but all it does is enter it as "filed" and not allow me to request again... now am totally stuck, as I cant delete/undo that - let alone request what I hope should be a v2 of the IT14 with Acc Loss present as you indicate. Eishhhhhh, what a mess
  12. #10
    Mar 2012
    Vanderbijlpark
    Go to the return but do not open it.
    Below it, one of the buttons says "Incorrect Return Type?"
    Click on that and select IT12R (I know, it should say ITR14)
    It should now generate the latest version and mark it it as "Saved".
    Alternatively, if that does not work for you, select Request a correction. The generated return should be the latest.
    If all that still fails, phone the call centre.
  1. [Question] Provision for Taxes
    By davidbann in forum Accounting Forum
    Last Post: 20-Mar-15, 01:52 PM
  2. [Question] CC Accumulated Losses
    By AmithS in forum Accounting Forum
    Last Post: 06-Aug-12, 07:10 AM
  3. IT14 Form
    By ltxrichard in forum Tax Forum
    Last Post: 19-Jul-12, 06:19 PM
  4. [Article] THE PROVISION OF FIRST AID BOXES AT THE WORKPLACE
    By BBBEE_CompSpec in forum Labour Relations and Legislation Forum
    Last Post: 03-Aug-10, 11:28 AM
  5. Help with IT14 please
    By TanyaK in forum Tax Forum
    Last Post: 25-Mar-09, 12:14 PM
