Results 1 to 8 of 8
Thread: NETWORK CONNECTION PROBLEMS
    Jan 2013
    Alberton
    Has anyone any suggestions on how to fix a network connectivity problem I am having. I have a windows 7 (64bit) bootcamp partition and am connecting it to a network (not a domain). I am able to see all the computers on the network except the Pastel server which is a windows 2003 server and a Belina payroll server which is a standard XP machine. I have flushed the ips I have checked the TCP/IP settings, I have checked the workgroup settings. As I mentioned I can all other computers on the network apart from the two mentioned.
    Feb 2013
    India
    When you go to your network folder you will get a yellow strip on the top of the page click on that and click network discovery on select your choice you will see the list of computers connected to your network weather WiFi or LAN.
    Gold Member irneb's Avatar
    Apr 2007
    Jhb
    Are those "servers" set to a different Workgroup (seeing as you're not using a domain)? It's highly recommended to use the same Workgroup name throughout (and turn off W7's Homegroup feature if you've got a mix of older Win machines as in your case). This would make network connections much easier.
    You're still lucky you're not having to connect to a 2000 (or even NT4) machine. That's simply impossible through Vista / W7. Ms decided those are not used any more, even though they are used extensively in old setups. If you've got one of these, then you're relegated back to XP as latest Win desktop.
    When you change network settings, it's worthwhile doing a restart - especially on older XP machines to make sure the new settings are actually being used.
    Jan 2013
    Alberton
    Quote Originally Posted by monaknight03 View Post
    Thanks so much for your reply I have done that and I see all the computers except the two I mentioned. If I go to one of the machines on the network and I ping the ip address of the computer I am trying to connect I can do that no problem. If i go on the problematic computer and I ping the ip address of the other computers on the network I have no success but if I ping the computer name it replies. The problem with this is that I am using Pastel and Belina and need the ip addresses in order to connect successfully
    Jan 2013
    Alberton
    Hi there, I have checked the workgroup settings and they are definitely all the same "workgroup"
    Jan 2013
    Alberton
    I def restart each time I make any changes.... but its win 7 OS however I still do the restart.
    Have you tried disabling IPV6 and only have IPV4 enabled?
  1. 230 volt generator with a V-O-V earth connection
    Last Post: 08-May-18, 03:20 PM
  2. Electrical Gas Stove connection and certificate
    Last Post: 29-Apr-16, 09:28 PM
  3. Internet connection speed
    By Martinco in forum Technology Forum
    Last Post: 11-Oct-12, 12:29 PM
  4. [Question] Changing colours for the switch connection
    By jinxster in forum Electrical Contracting Industry Forum
    Last Post: 12-Sep-12, 07:15 AM
  5. Problems with 3G
    By Chatmaster in forum Technology Forum
    Last Post: 16-Nov-07, 04:42 PM
