Results 1 to 3 of 3
Thread: solar lights installation
    Full Member kahoel117's Avatar
    Aug 2011
    cape town
    Is there any rules for powering domestic home lighting through solar power ?
    Meaning running all 220 VAC lights through a small solar system, which is only there to power the lighting of the home.
    So using the same switchgear and two circuit breakers for the lights, just from a different power supply.
    Is it allowable ??
    We touched on the subject in this stand alone solar installation discussion, so that might be worth a read.
    If you're switching between power sources for those lights, then the discussion on connecting backup generators to an existing installation might help.
    Both discussions are pre amendment 8 though.
    Aug 2011
    cape town
    Hi Dave .thanks.
    Had a read through , and very interresting.
    I guess almost anything can be done electrically , its just to make sure that the wiring laws is followed.
    Currently thinking of sizing up a solar system for 12vdc 5w led lamps (x20) and using that as an main source of lighting for the home, though i think i wont get the same brightness out of the lamps as i would with normal cfl's.
    I would save electricity though and will have light when eskom leaves us in the dark again.
    Kahoel
  1. Problem with outside lights
    By SparkyScott in forum Electrical Contracting Industry Forum
    Last Post: 02-Jul-12, 10:23 AM
  2. lem lights
    Last Post: 09-Dec-10, 09:04 AM
  3. Don't forget to switch out the lights.
    Last Post: 16-Jan-09, 03:23 PM
  4. And the lights go out again.
    By Dave A in forum Electrical Load Shedding Forum
    Last Post: 25-Feb-08, 04:38 PM
