Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Problem with outside lights
    Feb 2011
    joburg
    Hey guys I was just wondering if you could help me out please,I installed 2 outside lights eurolux FS96 floodlights about 2 months ago and been working fine.Yesterday the power was off most of the day,when they were suppose to come on the lamps started flickering and only 1 came on,tonight there doing the same one flickers and the other one doesn't do a thing.I checked the voltage and it was 183v at the light fitting then I checked the power at the mains and it was 189V,the sockets were 180v.do you think the power could be affecting the lights?
    Scott
    Sep 2010
    cape town
    190 volts is very low. better get eskom in there quick before your appliances fry.
    Wow, 180v at the sockets! I'm surprised anything electronic is working in that house. I would test the lights on a 220v supply before going any further. Why is the voltage so low? Is the neutral voltage elevated? I would run the usual barrage of tests at the incoming supply and see if the problem is in the house or Eskom.
    Feb 2011
    joburg
    Morning guys,I checked the sockets this morning and the voltage was 197 and the same at the mains.I never done any other tests but I will do when I get home and I will let you guys know.
    Just a question -
    Is the battery in your meter good?
    is your meter reading correctly?
    How did you test your meter?
    Power out for most of the day.
    Voltage problems there after.
    Coincidence? Probably not.
    Feb 2011
    joburg
    The municipality came out this morning and they said the clips on the mains cable in the street weren't on correctly and it was a new cable that was installed a few weeks back.there is now 210v at the mains and the outside lights are working.
    The tester is brand new and so are the batteries
    Scott
    Well 210volts is still a little on the low side but a step in the right direction from being in the 180's range. Might be worth putting the installation under a decent load and rechecking the DB supply voltage and neutral-earth voltage etc. Glad to hear it's all working again anyway.
  9. #9
    Sep 2010
    cape town
    at least its not 380 volts. i have seen a few times where city council gets mixed up and then they have to kak en betaal
  10. #10
    Apr 2012
    Vaal Triangle
    Well, if you train your artisans over a period of 18 months, module based, this is what happens. Problems.
  1. Low voltage down lights and ceiling earth bar
    By ColinK in forum Electrical Contracting Industry Forum
    Last Post: 08-Jul-11, 03:32 PM
  2. lem lights
    Last Post: 09-Dec-10, 09:04 AM
  3. [Article] Portable electric lights
    Last Post: 17-Sep-10, 09:54 PM
  4. Don't forget to switch out the lights.
    Last Post: 16-Jan-09, 03:23 PM
  5. And the lights go out again.
    By Dave A in forum Electrical Load Shedding Forum
    Last Post: 25-Feb-08, 04:38 PM
