Results 1 to 7 of 7
Thread: Pastel: Open Company Problem
    Bronze Member Elijah's Avatar
    May 2012
    Hi All, hope some-one can advise:
    I have a client using Pastel Express, when I choose open a Company the Dialog box is Empty. When I press the Manage Button the next Dialog Window is also empty. But the Company that was created is in the Pastel Folder. And Pervasive Database is running. What causes this problem and how can I resolve it.
    Morningside, Durban
    Hi Elijah,
    Is the second dialog window completely empty? If so, then try the following:
    Click on the Locate Server, and then browse to the Pastel folder, then to the Custom folder and then to the Registration folder.
    If that does not activate the company database, in which case you will get a message to the effect that the server is not registered, then it is possible that the computer has been renamed recently.
    Pastel's registration credentials are a function of:
    • The serial number;
    • The registered name;
    • The computer name.
    If either of the above three factors have changed, then you will not see the company database on the menu. If the computer has been renamed, then I suggest that you change it back to what it was.
    Col (01-Apr-15)
  4. #3
    May 2012
    Thanks Neville, Problem solved.
  5. #4
    Morningside, Durban
    Good news Elijah - what was the problem/solution?
  6. #5
    May 2012
    Quote Originally Posted by Neville Bailey View Post
    Hi Elijah,
    This solved the problem. Some-one had inadvertently, pressed the delete Server button.
  7. #6
    Nov 2014
    port elizabeth
    Hi,
    I have the same problem after a windows update.
    I went in to custom folder and clicked registration and all my files are there and show as added but as soon as I click close it all disappears again.
    Please help.
    Hi Elijah,
  8. #7
    Morningside, Durban
    Quote Originally Posted by Tisha View Post
    Hi,
    Please help.
    I presume you upgraded to Windows 8.1?
    If so, then have a look at the attachment - it should be self-explanatory.
    Attached Files Attached Files
  1. Pastel matching problem
    By vieome in forum Accounting Forum
    Last Post: 28-Jun-12, 08:25 AM
  2. [Question] Pastel losing a company
    By Martinco in forum Accounting Forum
    Last Post: 05-Jan-12, 09:39 AM
  3. Problem with printing of documents in Pastel
    By LyntonK in forum Accounting Forum
    Last Post: 07-Dec-11, 06:00 PM
  4. [Question] Changing Database name for Company in Pastel
    By J7J in forum Accounting Forum
    Last Post: 14-Apr-11, 01:48 PM
  5. A slight problem with a security company.
    By Pap_sak in forum General Business Forum
    Last Post: 06-Jan-11, 03:40 PM
