Results 1 to 5 of 5
Thread: Problems updating e@syfile
    Dec 2011
    Pretoria
    I seem unable to connect to e@syfile update server , with SARS I am logged onto internet and logged in as an administrator
    Can anyone help
    Is this to upgrade the software, or to update information/synchronise the application?
    Dec 2011
    Pretoria
    Most importantle the info to file for the new year .I suspect it is because we work through a Proxy it struggles to find but have no idea as how to solve it as I do not see any possible settings
    Normally the problem is you're not using the latest version of E@syfile. If you're not using the latest version, I've found that SARS's servers will not accept the connection request.
    However, if you are using the latest version and suspect a proxy server is blocking the communication, either:
    • Connect the PC directly to the internet without using the proxy, or
    • Backup the database using the E@syfile backup utility, install E@syfile on a PC that you will be able to use to connect directly to the internet, restore the backup onto the new machine, and try to run the part of the app you're having trouble with.
    If it works without the proxy server in the mix, then perhaps pursuing the proxy server settings might have merit.
    I must say I haven't had problems with my proxy server set-up, but it's all about the proxy server settings (which could become a pretty complex discussion).
    Dec 2011
    Pretoria
    I'll have a go
    Scottc
  1. E@syfile log-in security flaw
    By Dave A in forum Tax Forum
    Last Post: 23-Nov-11, 11:06 AM
  2. CSV file for e@syfile
    By liz in forum Tax Forum
    Last Post: 22-Sep-11, 03:20 PM
  3. E@syfile Transfer question
    By KimH in forum Tax Forum
    Last Post: 16-Sep-11, 02:54 PM
  4. e@syfile-employer not so easy this year
    Last Post: 25-May-10, 04:07 PM
